Does it improve efficiency?
What if the wing is just a plate? Certainly increasing plate thickness will decrease efficiency.
  • $\begingroup$ What do you mean closer to a wing? Along which axis? (ie moving a prop from nose to wing, or moving a prop mounted in front of a wing, back towards the wing, or moving a pusher prop forward to be close to the rear of the wing) $\endgroup$
    – tmptplayer
    Nov 18, 2019 at 1:10
  • $\begingroup$ @tmptplayer in front of a wing, moving closer to the wing as in reducing the distance between the prop blade and the leading edge of the wing $\endgroup$
    – xnor
    Nov 18, 2019 at 20:59
