21
When designing an aircraft, there has to be a decision as to the aspect ratio of a wing. It's been said that having a higher aspect wing will reduce drag for the same wing area, however most of the time wings are shorter than they can be. So my question is, what exactly dictates the aspect ratio of a wing, and why don't they make them as long as possible?
15
Now I am going to commit a heresy, but keep reading to get an explanation:
Increasing the aspect ratio of a wing will not change its induced drag. Increasing the span will.
The induced drag coefficient of a wing is $c_{Di} = \frac{c_L^2}{\pi\cdot AR\cdot\epsilon}$, and this seems to indicate that a bigger aspect ratio AR would lower the induced drag coefficient $c_{Di}$. But only at the same lift coefficient $c_L$!
Now let's look at the real numbers and compare two wings of the same span, but different aspect ratios. For simplicity, wing 1 has an AR of 5 and wing 2 has an AR of 10. Let's further assume that both wings have the same mass. Since both wings have the same span, wing 1 has twice the wing area of wing 2. To create the same lift, wing 1 needs only half the lift per area than wing 2! This means its $c_L$ is only half as big as that of wing 2, and now lets look at the induced drag again: $D_i = q_\infty\cdot S\cdot c_{Di}$
Wing 1: $D_{i_1} = q_\infty\cdot S_1\cdot\frac{c_{L_1}^2}{\pi\cdot AR_1\cdot\epsilon}$
Wing 2: $D_{i_2} = q_\infty\cdot S_2\cdot\frac{c_{L_2}^2}{\pi\cdot AR_2\cdot\epsilon} = q_\infty\cdot 0.5\cdot S_1\cdot\frac{4\cdot c_{L_1}^2}{\pi\cdot 2\cdot AR_1\cdot\epsilon} = D_{i_1}$
If both have the same span efficiency $\epsilon$, both have the same induced drag at the same lift. To reduce induced drag requires a span increase, regardless of aspect ratio.
However, a higher aspect ratio wing does have advantages:
  • Lower surface area means less friction drag
  • Lower surface area also means less mass, at least at moderate aspect ratios.
  • Smaller pitching moments, requiring a smaller tailplane
but also disadvantages:
  • Less internal volume for fuel or the landing gear
  • Needs more complex high lift devices for the same landing speed
In the end, the wing chord is chosen to minimize wing mass and to yield the minimum required fuel volume, and the aspect ratio is just a consequence of the selected wing span. Driving wing mass down is also reducing induced drag, and the $\epsilon$ of modern airliner wings is only 0.75 to 0.8, which shows how little importance the induced drag coefficient has for finding an overall optimum.
  • $\begingroup$ Woah that's heresy for sure. Never even thought an answer like this was possible, but it makes sense the more you think about it. $\endgroup$
    – YAHsaves
    May 18, 2019 at 19:02
  • $\begingroup$ @YAHsaves: It does make sense, indeed. It is less a heresy than clearing up a misunderstanding, but reading Wikipedia articles (and other web pages) cements an opinion in peoples' minds that is hard to change once it has been cemented by endless repetition. $\endgroup$ May 18, 2019 at 20:57
    $\begingroup$ Your answers on this site have busted at least a thousand misconceptions. I always enjoy reading the knowledge you have to share. This is in line with what you always say about drag being the consequence of lift being created over a finite length. Not a finite aspect ratio. $\endgroup$
    – YAHsaves
    May 18, 2019 at 22:09
    $\begingroup$ @PeterKämpf Since both wings have the same span, wing 1 has twice the wing area of wing 2. Then wing 2 must be at higher AoA to achieve same lift as wing1,so they end up with same induced drag. But if you compare two wings with different AR but same area,than wing with higher AR will has smaller induced drag when produce same lift as lower AR wing. $\endgroup$
    – user52248
    Sep 5, 2020 at 11:06
    $\begingroup$ @PeterKampf why do you compare it with same span,compare it with same area? $\endgroup$
    – user52248
    Sep 28, 2020 at 19:58
11
Aspect ratio is the ratio based on the span and chord of an aircraft's wings. The span is the length of the wings measured wingtip to wingtip; the chord is the 'depth' of the wing from the leading edge to the trailing edge, measured in a straight line.
Because very few aircraft have constant chord planforms, this requires a not-very-fancy formula to calculate (source: NASA), so that we can effectively average the chord:
$$AR=\frac{b^2}{S}$$
Where:
$AR=$ Aspect ratio
$B=$ Wingspan
$S=$ Wing's area
Math aside, aspect ratio is chosen based on an aircraft's role or requirements. A need for agility dictates a low aspect ratio, as does a need for compactness. In both cases, fighter aircraft and bush aircraft benefit from agility and small size. High aspect ratios provide great cruise efficiency but can have poor landing characteristics (high drag at low speeds or high angles of attack due to frontal area) that are often offset by high-lift devices like flaps and slats.
To the second half of your question: even when a high aspect ratio is desired, wings are not made as long as possible for two reasons.
The first is structural; the bending forces associated with wings of extreme length are, well, extreme, and the materials required are pretty space-age. See high-performance gliders, or at the crazy end, solar- or human-powered aircraft, for examples of this. It's just hard to do at the size of an airliner.
The second reason is more practical: space is expensive. An extremely high-aspect ratio wing takes up a ton of space relative to the rest of the aircraft. In an attempt to offset this, early 777s (which had a larger span than 767s and 747s) were offered with folding wingtips, but nobody bought that option and it got dropped.
  • $\begingroup$ Well, honestly you support that wings are made 'as long as possible' maybe we should edit it and say that the aspect ratio of a wing is trimmed for maximum efficiency under consideration of all aspects ;) But you gave a really good answer to this question, thank you, but please do me a favour: Wikipedia is not a real source... $\endgroup$
    – Falk
    Jan 8, 2014 at 3:57
    $\begingroup$ For higher speeds, the gain by reducing induced drag is offset by constantly rising parasitic drag. This is also a topic in gliding, where ever-increasing aspect ratios are challenged by more compact designs that work better at higher speeds. $\endgroup$
    – yankeekilo
    Jan 8, 2014 at 9:33
    $\begingroup$ Generally nice answer, but I'd like to question the "high aspect rations have poor landing characteristic". Increasing aspect ration reduces induced drag for given lift at all speeds, but induced drag increases with decreasing speed, so high-aspect wings provide most benefit at slow speed. They should therefore provide good landing performance. $\endgroup$
    Feb 10, 2014 at 19:48
    $\begingroup$ The new 777, called 777X, will feature folding wingtips by default. $\endgroup$
    – florisla
    Oct 2, 2014 at 15:46
  • $\begingroup$ Apart from this excellent explanation, is anyone can help me how to write equation in this stackexchange.com? $\endgroup$ Dec 15, 2018 at 1:23
To answer your question it's maybe helpful to remember why a higher aspect ratio generates less drag. A higher aspect ratio causes less induced drag at the same lift than an aerofoil with a lower aspect ratio. Okay, we need a certain amount of lift and our aim is to gain this lift as efficient as possible. Lets do it: Higher aspect ratio -> less drag, less drag less fuel burn, less fuel burn -> higher efficiency - perfect, but there are maybe other ways to reduce drag and safe for example space, or weight - a longer leading edge creates more form drag and where do you park this giant aircraft and it means a lot of weight to get sufficient strength for this giant wing - weight needs lift to fly and more lift causes more drag.
Okay, I think it's clear now, that it's not sufficient to consider only one way of tuning the efficiency of your aircraft. There are also nice possibilities like winglets to reduce induced drag for only a little extra weight and also just a little extra interference drag or a good range of possible CGs which requires left negative lift on the tail = less lift required at the wing. New materials and design techniques also allow to work on the all in all shape of the wing which increases the efficiency rapidly. Building a good aircraft is finding a good balance and so you can't just concentrate on only one possible solution.
I hope my wired talk can help you a little bit, sorry I fly this stuff and I guess all my colleagues are happy that I don't build it ;)
