How long did it take to set up those metal runways? Were the metal sheets spiked into the ground? How big were they? Also, how are commercial runways built?
$\begingroup$ What are you talking about? What "portable runway" are you asking about? Where was it built? When? $\endgroup$– Ron BeyerNov 13, 2019 at 1:41
2$\begingroup$ Welcome to aviation. SE! This question is sightly related. If you're new here please take the tour to see how the site works. We prefer one question at a time, for example. $\endgroup$– PondlifeNov 13, 2019 at 2:04
1$\begingroup$ Which runways? That might help us answer the rest of your questions. $\endgroup$– Camille GoudeseuneNov 13, 2019 at 2:29
$\begingroup$ It really depends on "where". $\endgroup$– user3528438Nov 13, 2019 at 2:50
$\begingroup$ You should remove the "also..." part of your question and ask that as a separate thread. $\endgroup$– SanchisesNov 13, 2019 at 6:43
1 Answer
Google is your friend. Try it. "perforated metal airstrip"
https://en.wikipedia.org/wiki/Marston_Mat
"A runway two hundred feet wide and 5000 feet (1500 m) long could be created within two days by a small team of engineers."
