The Pipstrel Alpha Electro Trainer has an electric engine which weighs 11Kg.
How much would the engine of a comparable gasoline powered aircraft weigh ?
Sign up to join this communityThe Pipstrel Alpha Electro Trainer has an electric engine which weighs 11Kg.
The Pipstrel Alpha Electro is an electric version of the Pipistrel Alpha Trainer which has a Rotax 912ul engine. The Rotax 912ul weighs 60kg.
For comparisons sake;
The Pipstrel Alpha Electro has a 11kg motor and 126kg of Lipo battery cells for a total of 137kg and about 1hr of flight time per charge.
The Pipistrel Alpha trainer has a 60kg engine and carries 35.5kg of fuel for a total of 95.5kg and 5-6hrs of flight time per tank.
flight time estimates are made assuming the planes are being used in a touch and go trainer role. At cruise speed flight times would be less.
EDIT for question in comments: The electric motor and Rotax engine both make 80hp. specs on the electric plane can be found here: https://www.aopa.org/news-and-media/all-news/2015/october/pilot/f_pipistrel and https://www.pipistrel-usa.com/alpha-electro/
Let me begin by saying I agree with the comment left by Ron, batteries are very heavy!
But to answer your question, Most medium sized trainers use a "360" engine built by either Lycoming or Continental.
A Lycoming O-360, an older, N/A engine fitted with a carburetor, weigh between 124.7kg and 137.4kg. Source.
Whereas when you "Kit Out" your Lycoming engine with a turbo and fuel injectors (TS-IO-360), they can weigh between 171.9kg and 184.6kg. Source.
If you're interested about what all the numbers and letters in an aircraft engine code mean, have a look at this Continental PDF documenting it all.
