It is all in the title.
I'm interested in power absorbed/used for a given thrust, or thrust generated for a given power (same diameters of course).
Just thrust and power. Ignore materials, electric vs turbine, complexity of the contra-rotating mechanism, etc.
Undisturbed inlet flow provides the highest efficiency.
  • The single rotor with stator has a straightforward inflow; outflow will have a tangential component which is lost for thrust generation. The stator will bend the outflow back in the axial direction, but there still remain pressure increases with blade passing frequency.
  • The contra rotating rotor has one of the rotors in the disturbed flow of the first rotor - this second rotor will therefore have lower efficiency in transforming engine power into thrust.
| improve this answer | |
