-1
  1. Upon landing, what percentage of weight is distributed on the main and the nose landing gears of fighters?
  2. Upon landing of a fighter aircraft, what would be the approximate time of transfer of the impact force on the landing gear?
  • $\begingroup$ Upon landing, the time to transfer impact force to the landing gear is “upon landing”, or effectively zero. What makes you think there is a delay, or am I misinterpreting your question? $\endgroup$ – Michael Hall Oct 26 '19 at 15:16
    $\begingroup$ -1 because you spend zero effort on the title $\endgroup$ – Christian Oct 26 '19 at 17:35
Depends (as usual...)
On normal landings all the force is taken by the main gear - the nose gear is still in the air. Later on it only takes a small force compared to the impact of touchdown.
But: not knowing what aircraft and what kind of landing (normal controlled on land vs. the "crash" of carrier landings), the answer would not be able to be more specific.
