The title says it all.
Can be clearly seen for example in this image:
(image source: Wikimedia)
The rest of the jet seems to have a camouflage.
Sign up to join this communityThe title says it all.
It is all part of the camouflage.
The blue parts on the bottom make the aircraft hard to identify from below against a blue-background (sky). The dark parts on the top make it difficult to identify from above against a dark background (ground).
The white parts make the aircraft's size/shape difficult to determine. This helps to confuse the enemy by making the aircraft seem farther away than it really is.
