What is the reason for making the empennage of this Lockheed L-1049E Super Constellation's design look so complicated with two vertical horizontal stabilizers? In my understanding, the more components installed, the more the weight of the airplane will be, and as a result will put more load on the engines, especially if there will be more actuators required. Do all the horizontal stabilizers have controllable surfaces? What is the reason for making the horizontal and the vertical cross each other, and not attaching them at their tips (marked with yellow and green circle)?
Edit: I corrected the question on the body from with two additional horizontal stabilizers? to become with two additional vertical stabilizers? as supposed to be as I marked in the picture.
