Hi I am planing on building a budget ultralight and I was wondering if a 6.5 hp 212 cc predator motor will be enough and if so what size prop should I use.
A little background, it is going to be a wood and foam plane with fiberglass covering I am going to have a few bits and pieces of aluminum for strength. I don’t have a plan yet because I am going to plan it around the engine. I am shooting for 160 pounds dry. Thank you in advance.
  • $\begingroup$ Even paramotors, that don't have any airframe (really just a propeller you strap on your back with some safety cage) use 20+ HP motors. 6.5 HP is not going to get you + airframe + fuel airborne without some very fancy modifications. $\endgroup$
    – Ron Beyer
    Oct 7, 2019 at 12:27
6.5 hp is enough to get a person off the ground - but it would require an extremely aerodynamically- and structurally- efficient airframe to do so. A first-time builder without experience or training is not going to build such an airframe on the cheap from wood and foam and fiberglass with "bits and pieces of aluminum for strength". Either the wings will break and you'll kill yourself, or more likely it just won't get airborne.
You should scrap this idea and instead find a good set of plans and follow them exactly.
There's a good reason most ultralights, even in the early days, used 3-5 times this much power: because 20-30 hp is the minimum needed to give reasonably safe takeoff and climb performance. You will not meet your goal of 160 lb dry if you provide enough wing area to lift that plus a pilot; even a fabric hang glider type ultralight, by the time it has a seat, landing gear, and engine mount, will be at or above this dry weight -- and even with your goal dry weight, add a pilot and five gallons of fuel, and you'll need a long takeoff roll to reach a safe takeoff speed.
You've got around 90 lb to spare under the ultralight limit (assuming you're in the USA): I'd recommend allowing half of that for overruns in the airframe, and putting the other half into a larger, more capable, likely more reliable power plant. Get something that's actually intended for ultralights -- you'll get more power per pound, which makes everything else better, and you'll decrease the likelihood of a failure at a critical time (like at low altitude after takeoff).
