In level flight at 400 knots, what happens when the speed brakes are extended?
1$\begingroup$ I'm guessing the speed brake would rapidly depart the aircraft... $\endgroup$ – Ron Beyer Oct 1 '19 at 13:24
$\begingroup$ Not true. The boards will be effective at all stages of the flight. What is the reason why you said that? $\endgroup$ – George Geo Oct 1 '19 at 13:27
2$\begingroup$ I forgot they were tail mounted devices on the F-16, I was thinking of the large flap that opens on the top of some aircraft. $\endgroup$ – Ron Beyer Oct 1 '19 at 13:32
1$\begingroup$ F15 has an "flap" on spine, it is top air brake , used for landing and in flight to slow down at any speed but it will not be fully open. $\endgroup$ – George Geo Oct 1 '19 at 13:44
Because the speed brakes are tail mounted, and because they deploy upwards and downwards equally, pitch should not change. The airplane's fly-by-wire system likely dampens any slight pitch changes caused by the buffeting.
The only photos I've seen of the speed brakes open are of them fully open, not partially open. So they may open gradually with different deflections up and down, or with different resulting air loads up and down, or both, or neither. But in any of those four cases, the FBW should correct for pitch excursions by deflecting the other control surfaces.
$\begingroup$ True, but ideally the pressure would have to be equal top /bottom. This is not the case with the body lift and chines of the F16. $\endgroup$ – George Geo Oct 1 '19 at 17:23
$\begingroup$ How do you know that they open symmetrically @George Geo? Top and bottom part angle may be different to keep pitch moment zero. $\endgroup$ – Jpe61 Oct 1 '19 at 19:08
$\begingroup$ Jpe61. The F 16 speed brakes are deployed always symmetrically up /down 60 degrees(same piston work to operate them ). Could be stopped at any angle. For landing is less because they risk to touch the ground. $\endgroup$ – George Geo Oct 1 '19 at 20:37
3$\begingroup$ This first thing that comes to mind is, you slow down. Shouldn't that affect the pitch? $\endgroup$ – ymb1 Oct 1 '19 at 23:35
1$\begingroup$ No need to toss around minus points when someones asks a legitimate question @George Geo. The fact that the speedbrakes are operated by single piston/pair does not automatically mean they open symmetrically. $\endgroup$ – Jpe61 Oct 2 '19 at 12:30
