I just got found ATC controller display on the internet and could you tell me what are these symbols indicating? For example the ones I highlighted in red?
1$\begingroup$ You might want to refer to the manual: ivao.aero/softdev/ivac.asp#doc $\endgroup$ – expeditedescent Oct 1 '19 at 6:24
The white squares are aircraft - it's course is indicated by a line. Then there is a datablock showing Callsign "FWA170C", its altitude F053 = Flighlevel 53 = 5300ft, climbing to an assigned flightlevel 190 = 19000ft. A = altitude - below a defined transition level F = flightlevel (steps of 100ft) - above a defined transition altitude
Transition altitude and level depend on the location and weather.
Then you have the airports, navaids, nav-fixes and the control zones showing.
$\begingroup$ I believe the C in FWA170 C (there is a space, I believe) might be transponder mode being Mode-C. $\endgroup$ – SentryRaven Oct 1 '19 at 14:07
$\begingroup$ @tsg thanks and how could the ATC know the aircraft is climbing to FL190? Is that reported by the aircraft? $\endgroup$ – VvV Oct 1 '19 at 16:26
2$\begingroup$ @SentryRaven C is an indication of the current sector ("Center"). $\endgroup$ – expeditedescent Oct 1 '19 at 17:00
$\begingroup$ @VvV Please get in touch with the IVAO training department. They have plenty of helpful resources. $\endgroup$ – expeditedescent Oct 1 '19 at 17:01
1$\begingroup$ @Jan, yes, and the short line coming out of the centre of the square is the current movement vector. I think its length is 5 min of flight, but I don't remember exactly now. $\endgroup$ – Zeus Oct 3 '19 at 3:05
