On chart plates it is written the minimum climb gradient with which an aircraft should climb for obstacle clearance or after ATC request (for traffic flow management etc.).
However, since this is the minimum required climb gradient, I am curious about what practically happens during real flights. For example, if a chart plate instructs an initial climb with a minimum climb gradient of i.e. 320 feet per nautical mile, will the aircraft try to maintain this minimum climb gradient until the termination altitude? Will it climb with the maximum climb gradient that its performance characteristics allow?
In other words, given an assigned climb gradient from a chart plate (i.e. from DEEZ5: "Standard with minimum climb of 250' per NM to 300), what would the average climb gradient of an aircraft during the initial climb phase be, provided that this value is taken into consideration not only for a lower but also for the calculation of an (hypothetical) upper limit?
