A question has been asked here before whether sliding vane compressors could be used in place of axial compressors on jet engines since they have a high compression ratio per stage (Why were rotary vane compressors never used in jet engines?), the answer being that the sliding seal would give out at the RPMs required.
What about a liquid ring pump?
It's essentially a sliding vane compressor where the seal is provided by the mass of liquid moving along the circumference. Is it possible to maintain a mass flow of the same order as axial compressors with these? Please ignore the question of cooling of the liquid for the purpose of this discussion.
