There are excellent explanations of the physics that determine maximum endurance speed here, here, and here.
I was thinking of aircraft that have to be "on station" without an indicated altitude and then wondering: Is maximum endurance not a function of both density altitude and speed? If so, what are the relevant variables and equations?
(I imagine that maximum L/D is a function of Mach number, so that might conveniently account for the effect of change in air density with altitude. But from the answers on max endurance speed I see that there are already differences between jets and props which, when air density is added, will result in further differences between turbo-props and piston props.)
    $\begingroup$ Mach number of a function of temperature, not pressure. $\endgroup$
    Sep 11, 2019 at 20:29
  • $\begingroup$ Maximum "endurance" IAS can be found found on your rate of descent vs glide speed chart. Density Altitude and engine selection become critical depending on Mach number (there for altitude) you wish to fly at a given IAS due to the "coffin" corner. So, if you wish to loiter (other than lighter than air), piston engines will give most power per given unit of fuel. You want low airfoil loading on both your wing and prop to stay away from higher Mach numbers. The lowly prop driven Helios flew to over 90,000 feet. $\endgroup$ Sep 12, 2019 at 9:09
The answer depends on many factors. Things to consider are:
  • Improved efficiency of combustion engines at higher altitude because of lower air temperature.
  • Lower power output with altitude due to lower air density, so the most efficient power setting coincides with the best endurance speed, which is close to stall speed.
But not all is better higher up:
There is more, but those are the main factors. So it depends on engine characteristics, wing loading, planform and airfoil and even on atmospheric conditions. This makes it hard to give a generalised answer – in the end the optimum has to be found for each design individually.
With all caveats, a good candidate for the optimum endurance altitude is close to the service ceiling of the aircraft when optimum loiter speed can be flown at the cruise power setting of the engine. If winds allow: A maximum of wind speed occurs near the tropopause, and in order to keep station even in high winds, it might be impossible to fly at best loiter speed. There are stories of Me-109s which should be flown to the western front from the plant in Augsburg and ended up on airfields in Czechoslovakia, because the pilot got caught in the then-unknown jet stream.
Wind speed diagram over altitude at 40N latitude
Wind speed over altitude at 40N latitude (picture source).
  • $\begingroup$ This is a good preliminary answer with some great information. For the purposes of this question ignore the winds aloft; i.e., loiter location is unimportant. $\endgroup$
    – feetwet
    Sep 20, 2019 at 18:22
