I was looking to get my restricted ATP at a university, but one of the requirements is to get my instrument rating from that university. Since I already have my instrument rating, but have not flown for 20 years, I would like to get my rating again through the university. Is it possible to retake my instrument rating again with the FAA? This would allow me to get my Restricted ATP with only 1,000 hours with 60 aviation credit hours from the university vs 1500 hours.
    $\begingroup$ While I’m not familiar with the university or if this is really their requirement, you could always surrender your pilot certificate... I don’t think you can surrender just the instrument rating. That would mean you would need to do your private checkride and written again. The thought of surrendering any of my hard earned certificates makes me cringe! $\endgroup$
    – Pugz
    Sep 7, 2019 at 20:14
    $\begingroup$ I would check more thoroughly if this is what they really require or if there is some other way to validate your IR through them, such as an IPC, or merely graduating from their IR program, even though you have already your rating. $\endgroup$
    – Pugz
    Sep 7, 2019 at 20:15
    $\begingroup$ This seems like a University specific policy question. $\endgroup$ Feb 27 at 18:45
-5
You don't still have an instrument rating if you've not flown in 20yrs. It is long expired and basically doesn't exist. Its best to do a refresher with CFII and take IPC eval when ready. Or you could redo the whole IR, and or re take the written. I belive the most current written is the one prominent in your file so yeah, go for a better score.
    $\begingroup$ Currency expires, the rating does not. $\endgroup$ Feb 27 at 18:44
    $\begingroup$ Your answer could be improved with additional supporting information. Please edit to add further details, such as citations or documentation, so that others can confirm that your answer is correct. You can find more information on how to write good answers in the help center. $\endgroup$
    – Community Bot
    Feb 27 at 21:01
