Let's assume, one of the engines on a twin-jet needs replacement and the jet is is fitted with an old engine and a newer engine after the due replacement, the older engine would tend to produce less thrust at higher fuel consumption due to deterioration on account of aging compared to the new one. Though the aircraft are designed to handle such asymmetries and modern FBW FCS should be able to handle it without bothering the pilot for any manual corrections, logically it makes sense to think one would like to do some basic engine matching to make sure the asymmetry is as small as possible. Do they follow this in real life? Are there guidelines in MRO procedures specified (both Civil and Military Jets) on how to choose a replacement engine, so as to maintain symmetry in the thrust profile?
$\begingroup$ A twin-jet should be able to fly and land with only one engine. This maximal thrust asymmetry should be tolerated too. $\endgroup$– UweAug 30, 2019 at 14:16
1$\begingroup$ @Uwe I mentioned the same in the question itself that the Jets are designed to handle such asymmetries. $\endgroup$– jaySAug 31, 2019 at 5:48
$\begingroup$ Yes, and pilots should be too. Good point Uwe! $\endgroup$– Robert DiGiovanniAug 31, 2019 at 7:35
It doesn't quite work that way. When an engine wears out it's rated thrust doesn't decline; its "ITT Margin" (or some similar phrase - basically its thermodynamic margin at takeoff) declines.
When setting takeoff thrust on a turbofan there is a target N1, or target torque on a turboprop or turboshaft, or Engine Pressure Ratio on a pure jet, and the engine has to achieve that target, so it's making rated thrust or power, more or less, no matter how old it is. What happens when it ages is the temperature required to get there goes up.
There is a maximum hot section temperature (Inter-Turbine Temperature - ITT or Turbine Inlet Temperature - TIT, or Turbine Outlet Temperature - TOT, or something else, depending on where the probe is) for the engine when producing takeoff thrust or power. On a new engine, the actual maximum temperature that you will see will be well below the maximum allowable (the temperature margin).
As the engine wears (turbine and compressor blade erosion mostly) and its efficiency declines, what happens is the hot section temperature when the engine is at takeoff rating goes up. It creeps higher and higher as the engine ages until eventually the margin is gone (or down to some minimum), temperature exceedences on takeoff may start to occur, and it's time to come off.
So there isn't really a thrust asymmetry problem with mixing new and old engines, although there will be a small fuel flow difference, but you have an automatic balancing system to account for this.
Staggering engine times is common. On an older, heavily depreciated jet especially, the engines may represent a huge part of the value of the airframe and it's a common practice to stagger the age of the engines avoid having to change out two at once when they wear out.
15$\begingroup$ That's also good for reliability. With two matching engines with identical use and maintenance history, if one fails, the other one has a chance of failing for the same reason, especially when you increase stress on it due to it being your only remaining engine. $\endgroup$ Aug 28, 2019 at 18:15
$\begingroup$ @john Thanks for the reply. makes sense for the Civil jets. But what about Mil jets..? I have read somewhere and also heard from Air Force Maintenance personnel that the Mil jets suffer thrust loss which could be as high as 15-20% as they come to end of life. Even Overhauls cannot recover the loss of thrust that happens between the two overhaul. I am thinking the loss of thrust is because Mil jets run at max TET possible right from starting without any margin left to cover deterioration. So any thrust shortfall cannot be compensated by increasing TET by the FADEC. $\endgroup$– jaySAug 30, 2019 at 7:09
1$\begingroup$ @jayS Mil jets are completely different. You need to actively prepare them for flight. There's a reason why a hurricane destroyed so many grounded F-22s; they weren't made ready to fly. $\endgroup$– NelsonAug 30, 2019 at 7:15
2$\begingroup$ Another interesting thing that happens is upgraded engine models will come out with increased thrust ratings, with the same core and higher hot temperatures, but without a max ITT increase. Effectively this shortens its service life. The CF-34-8C5A1 used on the CRJ1000 was affected by this. Operators were strongly encouraged to use flex thrust. $\endgroup$– John KAug 30, 2019 at 14:34
$\begingroup$ N1 limits are often a factor as well, as compressor erosion takes place. $\endgroup$ Aug 31, 2019 at 10:29
What they need to watch out for is applying the right stabilization process (thrust not to be applied in one go), even if both engines are brand new.
Manufacturing tolerances and age affect the acceleration profile and/or idle thrust, and it may lead to veering off the runway.
Any residual thrust difference thereafter would be minimal if perceptible (compared to a light crosswind breeze at best).
Source: Airbus
5$\begingroup$ This is why you "stand the levers up" first and let the engines stabilize in the 70-80%-ish range before going to TO thrust, to give them the best chance of arriving at bug N1 at the same time. $\endgroup$– John KAug 28, 2019 at 19:44
