Is it possible for an aircraft to stall when it turns multiple times before landing and its airspeed is below 200mph? And if it does, is there any way to recover at such low height and speed? I always get nervous looking out the window and feeling that 1.5g in my seat during landing.
$\begingroup$ Have you read the answers to this question: How does stall depend on angle of attack but not speed?? $\endgroup$ – Bianfable Aug 25 '19 at 21:37
2$\begingroup$ You need to remember that the pilots are the first occupants to arrive at the crash. They are well trained and experienced in control of the aircraft. Therefore they will not put themselves in the position of arriving first. $\endgroup$ – Mike Brass Aug 25 '19 at 22:45
When you learn to fly one of the first things that you learn is that recovering from a stall at low altitude is rarely successful. So we go up to at least 1,500 Above Ground Level (I like to go even higher) and we practice putting the airplane into a position just before it stalls—the stall warning light goes on and the wing begins to buffet. Then we use appropriate power, ailerons, and rudder to recover from the stall. Every pilot is tested on this before they receive their pilot’s license. Commercial pilots and air transport pilots are tested again with higher standards than private pilots. The idea is that you know the conditions that result in stalls and avoid getting into that situation. If for some reason you do stall the airplane, your training should kick in and you should be able to recover.
Unfortunately, many general aviation pilots get distracted on final approach and there are frequent stall-spin accidents in light airplanes. They are extremely rare in the airlines. The only one that comes to mind is the Colgan Air accident in 2009 where the plane iced up and the pilot flying ignored the stall warnings and pulled up on the stick instead of pushing the nose down and adding power.
We are taught that a stall can occur at any airspeed and any pitch if the airplane exceeds the critical angle of attack. There are lots of ways you can do that but the two most common are banking and icing up the wing. The Colgan Air crash is an example of the later. When the wings are iced up they do not provide as much lift as when they are clean. In order to keep the plane level you need to increase the pitch. This increases the angle of attack and at some point the wing exceeds the critical angle of attack and the plane stalls.
I am not aware of any recent airline accidents related to stalls while banking but there are plenty in light aircraft. An unfortunate series of events resulted in a stall spin accident in a Cirrus at Houston’s Hobby airport in 2016.
In the example you gave in your post of a 1.5 g load factor the stall speed increase is only going to be a few percent. So if you were in a Boeing 737 with a stall speed in the landing configuration of ~125 knots, the stall speed in the turn would be a few percent more—say 130 knots. The pilots know this information and will keep the angle of bank and airspeed within limits.
One of the maneuvers that we must master to get our Commercial license is steep turns of 50°. My Cherokee has a stall speed of 55 MPH in the approach configuration. The stall speed at a 50° bank angle is approximately 1.28 times 55 = 70 MPH. For me to successfully do a steep turn, I need to enter the maneuver at an airspeed of greater than 70 MPH.
Another maneuver that we must master is an accelerated stall. In this case we start out at our approach airspeed (in my Cherokee it is 80 MPH) and we bank to 45° and then pull up on the yoke. As you can guess from the discussion above, the airplane almost immediately stalls and then we recover from the stall. The reason we practice this maneuver is so that we don’t do this when coming in for a landing.
What causes pilots trouble is forgetting that your stall speed increases dramatically in a steep turn. Suppose you are turning to line up with the runway and you underestimate the wind and it blows you past the runway centerline. The natural reaction would be to steepen the turn. But when you steepen the turn you change the vertical component of lift so you start to sink toward the ground. If you pull up to get away from the ground you lose airspeed as well. So now you’ve increased the angle of attack past the critical angle of attack. The airplane stalls and if you weren’t coordinated with the rudder (which is often the case) the airplane enters a spin. This close to the ground they are rarely recoverable.
Stalls occur because the airplane exceeds the critical angle of attack. In most normal flying the angle of attack is directly related to the pitch and bank angles and the airspeed. We are taught how to avoid stalls in our primary training and when we get our refresher training every two years. We still manage to mess it up. Airline pilots receive much more training than we do and it is reflected in the accident statistics.
$\begingroup$ What aircraft did you train in that has a stall warning light? Did you mean AoA indicator? $\endgroup$ – Ron Beyer Aug 26 '19 at 3:57
3$\begingroup$ @RonBeyer My Cherokee has a stall warning light in the middle of the panel. Other aircraft that I have flown have a stall warning buzzer. $\endgroup$ – JScarry Aug 26 '19 at 6:01
