Which type of aircraft is more likely to avoid damage to the aircraft structure: high-winged aircraft or low-winged aircraft?
What factors influence the type of damage usually sustained during a crash?
    $\begingroup$ By crashworthy do you mean avoiding damage to crew and cargo, or avoiding damage to the aircraft? $\endgroup$ – Camille Goudeseune Aug 22 '19 at 17:43
    $\begingroup$ Related: What are the pros and cons of high-wing compared to low-wing design?. $\endgroup$ – PerlDuck Aug 22 '19 at 18:56
  • $\begingroup$ "What factors decide aircraft crashworthiness" I think you should explain that to us first. $\endgroup$ – zymhan Aug 22 '19 at 20:39
    $\begingroup$ By crashworthiness I mean avoiding damage to aircraft structure . $\endgroup$ – Vikas Singh Aug 23 '19 at 4:42
  • $\begingroup$ A design can not avoid damage: it can be designed to minimize the impact of being struck, however, reinforcement would be at the cost of weight. $\endgroup$ – gatorback Aug 23 '19 at 10:49
Regardless of wing position, a crash will damage most or all of the aircraft structure. Since low wings have dihedral, mild cases like a wheels-up landing will mainly affect the center fuselage rsp. the wing box. But most crashes occur in an odd orientation of the aircraft towards the ground, so at least one wing and the fuselage will suffer damage.
There are a few designs which will tolerate foreseeable abuse. On the Su-27, two long iron bars run along the lower fuselage and are the first to contact the ground in absence of wheels. After such a landing, the aircraft is simply jacked up and put into service again.
Su-27 on the ground after belly landing
Su-27 on the ground after belly landing (picture source). Just look at the paint job – the abuse this aircraft suffered is not restricted to this unorthodox landing style.
The main gear of the A-10 only partially retracts, so the bottoms of the wheels stick out of the gear bays and will contact the ground first. A belly landing with an A-10 will require a bit of repair but normally the aircraft is back in the air within a week.
A-10 on the ground after belly landing
A-10 on the ground after belly landing (picture source). The landing gear design is on purpose: It limits damage in a belly landing. Few aircraft have been designed with such foresight.
Similarly, for tail strike testing a bumper structure is added at the lower rear fuselage. In absence of such precautions, lengthy workshop stays are unavoidable.
But most crashes are less benign. The main factor in a crash is the relative velocity between the aircraft and the structure it crashes against. In most cases, this is a sizeable portion of flight speed, so the energies involved are immense (mass times velocity squared, divided by two).
Boeing 737 Crash site
Boeing 737 Crash site (picture source). As can be seen, both wings and fuselage are heavily damaged. The wing location was not a factor in the extent of the damage. That is how a real crash looks like. Unfortunately.
    $\begingroup$ Even in a relatively "benign" crash, it gets bad real quick. Consider the debris field or Asiana 214, a B777 which crashed by executing pretty much a normal landing, just somewhat short of the runway. Despite the damage, there were only three fatalities, two of which were determined to not have been wearing their seatbelts during the landing. $\endgroup$ – a CVn Aug 23 '19 at 19:24
Unfortunately, weight saving efforts in aircraft design render them "not very crashworthy", a bit like comparing an aluminum can (aircraft) to a steel one (car).
The high wing offers a slight advantage in that it (very importantly) gives greater latitude of control just prior to crash by enabling a higher degree of freedom in roll angle without catching a wing tip. This is especially critical in a water ditching (see sea plane design).
So you want your "crash" to be as much like a normal landing as possible.
While a low wing may offer the advantage of absorbing more energy while the crash is in progress, catching a wing tip and "cartwheeling" is disasterous and will result in a rapid disintegration of the aircraft and non-survivable forces on its occupants in many cases.
