Can someone help me define “blade scatter” gas turbine compressor dynamic balancing?
2$\begingroup$ What help do you need? Is there something about an existing definition you don't understand? $\endgroup$ – CatchAsCatchCan Aug 21 '19 at 5:12
$\begingroup$ I cant’t find the definition of “blade scatter $\endgroup$ – Arjay Pasague Aug 21 '19 at 9:13
$\begingroup$ Do you have any context for this term? Where/how is it being used? $\endgroup$ – Daniel K Aug 21 '19 at 10:31
$\begingroup$ Sorry for incomplete information. Actually I’m looking for phenomenon called “blade scatter” during dynamic balancing. And it is due to what? Thanks $\endgroup$ – Arjay Pasague Feb 22 '20 at 14:19
I assume there is an ellipsis somewhere in your source text, meaning the intended interpretation is "blade weight scatter", which does make sense in the context of dynamic balancing.
The meaning should be self-explanatory: the distribution of weights among nominally-equal turbo-machinery blades, which is important to keep the inertia tensor of the assembly as diagonal as possible when using the usual axis.
