Are there any legal requirements concerning airline pilots and their watches? Do they have to be of any particular kind and are pilots required to wear one at all?
2$\begingroup$ Closely related $\endgroup$ – Pondlife Aug 18 '19 at 22:06
$\begingroup$ Not worth an answer but the only thing I can think of is that it can't get in the way of operating the plane. So no Flavor Flav style -- um -- stuff. $\endgroup$ – coteyr Aug 19 '19 at 19:03
Well, a wristwatch can't be used to sneak around the requirement that IFR requires a clock mounted in the aircraft, FAR 91.205(d)(6). A missing or inoperative clock isn't likely in a modern airliner. As far as the FAA is concerned, a wristwatch is nothing more than jewelry.
Ages ago, a wristwatch may have helped with calculating fuel burn and range, but even then, it was a convenience rather than mandated equipment.
7$\begingroup$ FWIW, I've had my PPL since the late '70s, and have never owned or worn a wristwatch. $\endgroup$ – jamesqf Aug 19 '19 at 1:14
38$\begingroup$ BUT, if you do wear one it has to be a large, blingy, one that leaves no mistake as to your status as a cool dude pilot :) $\endgroup$ – jwenting Aug 19 '19 at 3:49
10$\begingroup$ A pity that we have no rear bumpers to proclaim, my other cessna is a porsche. $\endgroup$ – Camille Goudeseune Aug 19 '19 at 4:27
3$\begingroup$ @CamilleGoudeseune - "My other plane is a Porsche-Mooney" may be more appropriate... :) $\endgroup$ – ivanivan Aug 19 '19 at 13:52
