Is a high alpha sideslip possible and safe?
We use a sideslip to increase drag when trying to reduce altitude before landing on a short runway, etc., which is crossing your rudder and ailerons, to produce an angle to the intended direction, usually in level flight.
Is it possible to do a sideslip at an AOA of say 15 deg for even more drag, assuming stall angle is at 30 deg?
  • $\begingroup$ Let's assume that to first approximation, a given rudder deflection (say, full deflection) creates a given slip angle of the fuselage. So for a given rudder deflection, don't you generate a lot more drag (and also sideforce- thus requiring a steeper bank angle if you wish to maintain a linear flight path) if you are flying at a HIGH airspeed than at a LOW airspeed? So, there may be a wrong premise imbedded in this question. $\endgroup$ Aug 17, 2019 at 13:58
  • $\begingroup$ What kind of aircraft are you flying which stalls at 30°? Convair F-106? MiG-21? $\endgroup$ Oct 6, 2019 at 17:56
You would be risking your life. Cross controlled approaches should only be done well above stall speed and only after testing at a higher altitude. Increasing AOA will slow your plane down. If you recognize being high early in the pattern, you might be better off going ABOVE Vbg and slip, which makes the plane glide much less efficiently. Spoilers act in a similar manner.
Do a proper approach and use your flaps/spoilers. If it is allowed, forward slip to increase rate of descent at your preferred approach speed. If you can't make the runway GO AROUND. Changing speeds on short final will make judging the landing much more difficult.
In an emergency landing it is far better to over shoot the field and roll into fence, trees, etc at 10-20 mph than to risk losing control of the plane.
As a side note, only deltas come close to 30 degrees AOA before stalling, and these tend to drop like a rock when slipped if their vortex lift is sufficiently disturbed. Slats and flaps will significantly increase stall AOA, but at the expense of much more drag.
Generally a bad idea.
  • $\begingroup$ Zenith 701 pilots do short takeoff or landings ( STOL) at 30 deg AOA all the time, I'm told. Just not sideslipped I guess. $\endgroup$
    – Fred
    Aug 16, 2019 at 23:26
  • $\begingroup$ @Fred from my own experience in a 172 the airflow can get pretty crazy when slipping with everything "hanging out". So I would check the POH and talk with pilots experienced in operating that particular type of plane. It may be possible, I just wouldn't do it near stall. $\endgroup$ Aug 17, 2019 at 0:28
  • $\begingroup$ Flaps actually decrease the stall AoA a bit (but still increase the maximum lift). Slats increase the stall AoA, which is why they are always extended before flaps to compensate for the reduction due to flaps. $\endgroup$
    Oct 6, 2019 at 15:40
  • $\begingroup$ @Jan Hudec that is true, relative to the AOA sensor (on the fuselage). Both create a higher lifting cambered wing, which allows lower AOA, or airspeed, for the same lift. $\endgroup$ Oct 6, 2019 at 16:17
    $\begingroup$ That's a good point. You can get steeper descent on the back side of the power curve with increasing AOA; but flaring on the back-side would be a whole different story... $\endgroup$
    – JZYL
    Aug 17, 2019 at 15:03
  • $\begingroup$ That is exactly right +1. $\endgroup$ Aug 17, 2019 at 17:52
Yes it's safe as long as you know what you are doing and there is adequate alpha margin while slipping, and you are adept at managing the energy of the very high sink rate that results. If you were approaching in something like a 701 at, say, 35 mph, and you wanted to slip to increase the descent rate, you could do so but it would be prudent to reduce alpha somewhat and add energy by speeding up a few mph while in the slip. So you would do it like any other airplane, kick in the slip and lower the nose a bit at the same time, maintaining ample margin above stall. So if the stalling AOA is 25-30 deg and you are at 15 at your normal STOL approach speed, not a problem.
The main thing is, in a STOL airplane with very high drag in the landing configuration, you have to make sure you have energy to arrest the sink rate close to the ground by having excess inertia energy and being ready and aggressive with power to control the last bit before touchdown. The wing may not stall until it's at 30 deg, but when it's getting up there the drag is massive and the increase in lift with extra pitch declines and you can find yourself dropping out and landing hard, even though you are not actually stalled.
