What is the typical fuel consumption of a Boeing 737 in MPG?
  • $\begingroup$ Are you interested in MPG, or actually interested in things like emissions/mile or cost of fuel? Emissions between a gallon of gasoline and gallon of jet fuel are close but not equal, and the cost is very different. $\endgroup$
    – Cody P
    Aug 12, 2019 at 17:02
11
The following table shows the long range cruise control data for a Boeing 737-800 (source: FCOMv1 Performance Inflight - All Engine PI.31.2): 737 FCOM
Let us consider a typical cruise at FL370 with a weight of $ 65 \, \mathrm{t} $. The table tells us that the fuel flow per engine would be:
$$ \mathrm{FF} = 1231 \, \mathrm{kg}/\mathrm{h} $$
We are interested in the fuel consumption per distance, not per time. The table tells us that we would fly at Mach $ 0.793 $. At an altitude of $ 37 \, 000 \, \mathrm{ft} $ the speed of sound would be $ 295 \, \mathrm{m}/\mathrm{s} \approx 574 \, \mathrm{kt} $ assuming ISA (International Standard Atmosphere) conditions. This gives us the cruise TAS (true airspeed):
$$ \mathrm{KTAS} = 455 $$
The resulting fuel economy is then:
$$ \frac{2 \times \mathrm{FF}}{\mathrm{KTAS}} = 5.41 \, \mathrm{kg}/\mathrm{NM} $$
You asked for MPG (miles per gallon), so we need to convert that mass of fuel into a volume. The density of jet fuel depends on temperature. Assuming you refer to the volume on the ground, let us assume $ \rho = 0.820 \, \mathrm{kg}/\mathrm{l} $ for Jet-A. This gives:
$$ 1.51 \, \mathrm{gal}/\mathrm{mi} \; \Rightarrow \; 0.66 \, \mathrm{MPG} $$
All of this assumes no wind. If there is a $ 50 \, \mathrm{kt} $ headwind for example, the ground speed (GS) would reduce accordingly ($ \mathrm{GS} = \mathrm{TAS} - \mathrm{Headwind} $). Using this instead of KTAS in the equations above gives:
$$ 50 \, \mathrm{kt} \; \mathrm{Headwind}: \; 0.59 \, \mathrm{MPG} \; ; \; \; 50 \, \mathrm{kt} \; \mathrm{Tailwind}: \; 0.73 \, \mathrm{MPG} $$
Note: This is for the entire aircraft. If you are interested in fuel economy per seat, multiply the MPG with the number of seats (189 is the exit limit for a 737-800).
It's not fixed, some of the variables are:
  1. Which 737 family and variant
  2. Flight (air) distance, which is affected by wind
  3. Passenger load.
In general, for any current jet-liner's fuel mileage, I recommend Wikipedia's article on aircraft fuel economy. The figures are well-sourced, and structured nicely. Just remember to divide the mpg values there with the number of passengers from the same row if you are more interested in the whole plane.
For a 737-800 with 162 passengers on a 1000 NM trip, it's 96 mpg per passenger, or 0.593 mpg for the whole plane.
  • $\begingroup$ These variables are also important because there's an assumption that if you're riding a 737, certain load factors and distances are more likely. For example, riding a 737-700 you're more likely to be flying an intermediate distance and low load factor compared to, say, a 787. $\endgroup$
    – Cody P
    Aug 12, 2019 at 16:57
