In the A320 MEL if Ignition system A is under MEL the aircraft can't be dispatched for ETOPS. Why is it specifically restricted for ETOPS because even while conducting non ETOPS if we go into emergency electrical configuration we will still lose ignition system A.
Your assumption is incorrect.
In ELEC EMER CONFIG (see your QRH - ELEC EMER CONFIG SYS REMAINING), Ignition A is the only ignition available and hence that would be your reason why IGN A is needed for EDTO / ETOPS.
    $\begingroup$ this is not my assumption but mentioned in the official MEL document of my company. $\endgroup$
    – Jai
    Sep 17, 2019 at 8:11
