As this question indicates, I've been thinking recently about the environmental impact of flying (since when automated cars are the only means of ground transport, aviation will be responsible for most greenhouse emissions).
So, as an amateur, novice pilot, I would like to know which is more environmentally friendly, learning in a glider or learning in a single engine prop (Piper Tomahawk, Cessna and the like)?
At first it seems obvious, the glider doesn't have an engine while the latter does. But if we assume the launch method of the glider is tow rope, this would be powered by a single engine prop, using more fuel than it would if it wasn't towing, plus the climb is the most fuel-expensive part of the flight anyway, leading me to think there might not actually be that much difference.
Clarification on this issue would be greatly appreciated.
