My two projects right now are learning to fly and 3D modeling a replacement blade for antique fan, and a question occurred to me:
Why are airplane propeller blades not shaped like household fan blades?
They're both designed to push the same fluid with some degree of efficiency, but household fan blades look a lot more like ship screws/boat propeller blades. Is it a weight issue? A visibility issue? A drag issue, and if so, how?
EDIT - This is not a duplicate of this question because the proposed answers a question about angle of attack and pitch, which are aviation jargon words that may mean nothing to novices. Pitch and angle of attack also have little to do with the front-view shape of a household fan or prop blade, which is likely the most obvious difference between the two types of blades in the eyes of someone without an aeronautical engineering degree.
