Two aircraft with same airspeed, blank angle, but different mass, are the radius of turn the same?
2$\begingroup$ What have you done to try and answer this homework question by yourself? Where are you stuck? $\endgroup$– AEhere supports MonicaJul 24, 2019 at 16:21
$\begingroup$ Are the aircraft the same type? Same wing configuration? Are they flying at the same altitude and speed? $\endgroup$– florislaJul 25, 2019 at 9:56
Add a comment
