With power off, is it possible to maintain constant altitude for some period of time, until the 1-G stall speed is reached, i.e. until the stall angle-of-attack is reached?
Implicit in the question is the assumption that the initial airspeed is above the 1-G stall speed.
    $\begingroup$ Why ask such a question? The answer seems completely obvious, but discussion under this related question aviation.stackexchange.com/questions/66366/… suggests we may see some "interesting" answers posted. $\endgroup$ Jul 9 '19 at 14:38
  • $\begingroup$ @AEhere -- modified. Anything else that you need to know? $\endgroup$ Jul 9 '19 at 14:43
  • $\begingroup$ No, I just wanted you to avoid needless discussion by eliminating the trivial case. $\endgroup$ Jul 9 '19 at 14:49
Yes, assuming your are flying level with the engine running and then you turn the engine off, the following will happen:
  • Without power from the engine, the drag will cause the airspeed to decrease.
  • Lower airspeed at the same angle of attack implies less lift. Since you want to maintain altitude, lift needs to stay the same (your weight has not changed). Thus, you have to increase pitch.
  • Eventually, you will reach the critical angle of attack and flow separation will occur, i.e. you stall. The airspeed at which this happens is called the 1-G stall speed, although one can stall any speed.
Yes, this is how you practice stall recovery.
  • reduce power to idle
  • continue pulling back (that is to say, increase angle of attack) to maintain altitude until stall warning sounds
  • recover by lowering the nose and then re-applying power
  • $\begingroup$ Btw it's not how I usually practice stalls-- why worry about holding altitude exactly constant? Exactly what is gained by that? But it is indeed a common way to practice stalls. $\endgroup$ Jul 9 '19 at 14:47
  • $\begingroup$ I didnt say "exactly constant". I said "maintain". If you constantly lose altitude while practising stalls it just prolongs the amount of time you're maintaining slow flight, and the possibility of an unexpected wing drop. $\endgroup$
    – Jamiec
    Jul 9 '19 at 14:49
  • $\begingroup$ ... plus if you know how to practice a stall, then you know the answer to the question. $\endgroup$
    – Jamiec
    Jul 9 '19 at 14:50
  • $\begingroup$ I don't mind the downvote for asking an obvious question, but if you are curious about the context and motivation, read the comments under aviation.stackexchange.com/questions/66366/… . $\endgroup$ Jul 9 '19 at 14:54
