Why have modern airliners converged on a configuration with two or occasionally four underwing engines, while modern business jets have converged on a configuration with two or occasionally three rear-mounted engines?
I am of course aware of the many past airliners with rear-mounted engines, with the DC-9 and MD-80 and later derivatives continuing into production until rather recently, but it still seems fair to say that the underwing configuration dominates modern airliner design.
Meanwhile business jets exclusively use the rear-engine design, unless one counts small airliners put into business service such as the Boeing Business Jet. Does the underwing engine design simply not scale down well to something the size of a smaller business jet?
Here's a related question with good answers but still doesn't really answer my question-- How does the mounting location of a jet engine affect aircraft performance?
One key factor now occurring to me is that business jets are boarded with self-contained airstair doors/ steps so a fuselage sitting high off the ground would be problematic. Airliners with long fuselages perhaps may need rather long landing gear to provide adequate ground clearance for rotation anyway-- although the DC-9 / MD-80 with its wing and landing gear far to the rear did sit rather low to the ground-- still in the airliner situation perhaps there simply is not as much benefit to having a low-sitting fuselage as there is in the business jet situation.
Of peripheral interest is this Wikipedia article on "airstairs", pointing out some cases where full-blown airliners are equipped with airstairs. One of the more interesting lines is:
The most unusual airstair design was found on the Lockheed L-1011, which was a full-height airstair which was stored in a cargo compartment and allowed access from the right aft passenger door to the ground. This design was ultimately so large and heavy, and it took up valuable cargo space, that it was rarely used.
