Would a Chinook perform better or have any advantage with dual contra-rotating propellers over a Chinook with just normal counter-rotating propellers?
4$\begingroup$ What kind of advantage/issue are you looking for/want to fix? Please narrow down the issue to get more relevant answers. (How do I ask a good question?) $\endgroup$ – ymb1 Jul 1 '19 at 23:50
$\begingroup$ There seems to be a lot of confusion around this question. First, it's not clear whether you mean contra-rotating (two rotors turning in opposite directions on the same axis) or counter-rotating (opposite directions on different axes). The Chinook does have counter-rotating rotors, but not contra-. It's not clear what your image shows or where you got it from. It appears to be some sort of model: does it have contra-rotating blades? $\endgroup$ – David Richerby Jul 2 '19 at 17:51
$\begingroup$ @DavidRicherby yes contra and it does have contra and not counter. $\endgroup$ – Muze Jul 2 '19 at 20:06
$\begingroup$ @Muze I thought the question was clear and have edited my answer to try to avoid suggesting otherwise. $\endgroup$ – quiet flyer Jul 2 '19 at 20:47
The Chinook DOES have contra-rotating rotors, in a sense. The front and back rotors turn in opposite directions. (Actually, the correct term for this is "counter-rotating".) Read more on this elementary physics page about torques and angular momentum-- https://learn.parallax.com/tutorials/robot/elev-8/understanding-physics-multirotor-flight/rotation-torque-and-angular-momentum
Of course the question was clearly asking about true contra-rotating rotors-- two rotor disks rotating in opposite directions on each rotor mast. This might have a few advantages-- like allowing the Chinook to tolerate an even greater fore-and-aft variation in CG-- but would obviously introduce a great deal more complexity. Whether it would fly "better" is hard to say-- the energy lost through the additional gearing, as well as the energy expended to lift the extra weight, might not offset any theoretical aerodynamic advantages.
Here are some interesting additional tidbits of information about the Chinook--
There is no fore and aft (cyclic) movement in either disk. (There can't be, they'd strike each other.) Aircraft pitch is controlled by differential collective between the disks.
Roll is produced by lateral (cyclic) in both disks simultaneously, and yaw by differential lateral cyclic, if you follow my terminology.
Actually there is a slight fore and aft input by a system called LCT (Longitudinal cyclic trim) that tilts the gearboxes fore and aft to reduce excessive deck angle at speed, but it is not part of the primary flight controls. Conventional flight controls produce these rather unusual inputs via a very complex mechanical mixing unit in the broom cupboard behind the P1.
Due to the dynamics the Chinook develops maximum translational lift in sideways flight to the left, hence the antics of the logging machines plunging sideways on the end of their long cables - gives them greatly increased lift capacity.
Source of quoted material above-- this post (#2) in another forum-- https://www.pprune.org/rotorheads/163538-chinook-other-tandem-rotors-discussions.html#post206883
Note that yaw control is NOT dependent upon the difference in the torque applied to the front and back rotors. Therefore it's clear why this unique and interesting design could tolerate a large variation in fore-and-aft CG, even without the added complexity of a pair of contra-rotating rotors at each rotor mast. In fact, since the rotors are mechanically locked together (see below), it must often be the case that one rotor is absorbing more torque from the transmission system than the other rotor.
A few more bits of interesting information about the Chinook--
The rotor blade systems, though mounted on masts of different height, apparently sometimes do actually intermesh in flight. However they are mechanically locked together by the transmission gearing so that they are forced to turn at the same rpm so the individual blades cannot strike each other.
(This may call into question the statement above that it that it would not have been possible to design the Chinook control system to include collective pitch inputs to either rotor because the blades would strike.)
The difference in height of the rotor mast heads is indeed quite noticeable when you take the fuselage top as a reference. However, in-flight images show that the fuselage itself is tilted up in slow flight (as well as on the ground), so a part of the difference is already gone then. Most of what remains is further eaten away by the difference in rotor mast attitude: the shorter mast of the apparently ‘lower’ front rotor is tilted forward, away from the rear rotor mast. The front rotor mast is tilted towards the nose, and the rear rotor mast is also tilted slightly forward, but less so than the front one.
Now add the real life variations of the actual blade height when passing over the fuselage top due to cyclic pitch and ‘rudder pedal’ inputs (blade flapping) and turbulence (blade flapping and flexing). And factor in the considerable blade droop (downward bending) when parked and on initially setting the rotors in motion.
I hope my contribution counteracts the inevitable legend of the often mentioned apparent difference in height of the two rotor discs: in real life the two rotor discs mesh more or less all of the time. The mechanical synchronization is indeed the crucial element, just like in the egg beater. The mast height difference and the related fuselage attitude are there for other reasons.
Source of quoted material above-- second answer on this thread-- https://www.quora.com/Why-dont-the-Chinook-helicopter%E2%80%99s-rotors-collide-with-each-other -- Answered May 3, 2018 by Frank Sturm, former Flight Ops. Engineer at Martinair Holland (1979-2003)
$\begingroup$ Just for added interest here a link to a maintenance/ troubleshooting manual for the Chinook-- chinook-helicopter.com/Publications/AMTFH/… $\endgroup$ – quiet flyer Jul 2 '19 at 13:40
1$\begingroup$ I think the question is asking about actual contra-rotation, not using the wrong term for counter-rotation. $\endgroup$ – David Richerby Jul 2 '19 at 17:55
$\begingroup$ Agreed, was kind of making a joke or being a smarta**, have edited to not suggest question was using wrong terms. $\endgroup$ – quiet flyer Jul 2 '19 at 20:36
No. The RC model there is using counter-rotating rotors because the upper rotor with the stabilizer bar has a specific function that makes the model controllable in the first place.
The Chinook already benefits from built-in anti-torque control so that would be a waste of time and oodles of money on the real one.
Fun fact about the Chinook: it can climb better, and fly on less power overall, going sideways. Both rotors are able to bite clean air, achieving translational lift, when going sideways. When going forward, the rear rotor has to cope with the wake of the front one.
$\begingroup$ Do you mean counter-rotating or contra-rotating? The real Chinook does have counter-rotating rotors (one turns clockwise, the other anticlockwise). $\endgroup$ – David Richerby Jul 2 '19 at 17:55
First, a little nomenclature: Contra rotation is opposite rotation on the same axis, as seen on the Tu-95 bomber. This increases the efficiency of converting horsepower to thrust in a prop design. Counter rotation is two props spinning on 2 DIFFERENT axes, whose torque effects cancel, as seen on the P-38 Lightning.
The Chinook benefits from counter rotating props (on 2 different axes) as a cargo carrier because it can adjust its center of lift to match the variations in CG of different cargo loads. Moving one prop under the other would lessen this advantage, but mounting 2 sets of contra rotating props would be possible.
May be a possible, but not needed change.
As far as flying better sideways (going Osprey?), a great point by John K.
$\begingroup$ Interesting tidbits about the Chinook-- see added quotes in my answer-- $\endgroup$ – quiet flyer Jul 2 '19 at 13:14
2$\begingroup$ This post can be summarized in just one word, that is "Maybe". $\endgroup$ – Jenc Jul 3 '19 at 9:11
$\begingroup$ "The Chinook [...] can adjust its center of lift to match the variations in CG of different cargo loads" Can it? Aren't the rotors mechanically linked so they keep the same rpm? Setting different collective pitch values on them will yaw the airframe, so any "lift adjustment" would be via cyclic trim, like any other helicopter. $\endgroup$ – AEhere supports Monica Jul 11 '19 at 7:38
$\begingroup$ Yes, they can! See tandem rotors on Wiki. Imagine the tail rotor migrating to the top like the eye of a flounder as it grows. The tandem works more like a wheel barrow than a unicycle for varying CG loads. So you increase collective on the heavy side and use cyclic to control the resulting yaw. $\endgroup$ – Robert DiGiovanni Jul 11 '19 at 14:26
$\begingroup$ I honestly don't get your similes most of the time and this is no exception, but FM 3-04.203 explains it nicely and you are right about yaw control in tandems, at least American-made ones. I was thinking about coaxials since I am more familiar with them. $\endgroup$ – AEhere supports Monica Jul 12 '19 at 11:57
