I know many airports do not allow ultralight aircraft but can I take it to work, home, or to the bar? What is the limits of freedoms of travel in an ultralight?
closed as too broad by GdD, ymb1, bogl, David Richerby, fooot Jul 1 at 16:53
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    $\begingroup$ Possible duplicate of What regulations are in place for ultralight vehicles flying over US national parks? $\endgroup$ – AEhere Jul 1 at 14:56
    $\begingroup$ I don't think the picture you posted fits the definition of an ultralight in the United States. $\endgroup$ – Ron Beyer Jul 1 at 15:15
  • $\begingroup$ en.wikipedia.org/wiki/Workhorse_SureFly "The 70 mph (110 km/h) hybrid electric has a 200-hp gasoline generator giving up to 70 mi (110 km) range over 1 hour. It has four propeller arms, each with two electric contra-rotating propellers powered by a gas turbine or piston engine generator along a battery pack. Targeting a price of $200,000, it can lift a 400 lb (180 kg) payload and include a ballistic parachute. The SureFly would operate as a conventional helicopter, like the similarly priced two-seat Robinson R22, but would be easier to fly and safer with its integral parachute. " $\endgroup$ – CrossRoads Jul 1 at 15:49
Taken from a more specific answer by @Pondlife to a question about ultralights and National Parks:
For ultralights specifically, the regulations are in 14 CFR 103 which has only a few very simple restrictions on where ultralights can operate. 103.15 says you can't operate over a congested area or a crowd of people and other restrictions are the obvious ones: don't fly near airports without ATC approval, don't enter restricted airspace, and do follow NOTAMs.
  • $\begingroup$ I understand you were giving a basic-level answer but actually for MOST airports without control towers there is no need to get ATC approval before flying an ultralight there. $\endgroup$ – quiet flyer Jul 2 at 1:35
