The Schempp-Hirth Duo Discus T powered glider has a five-bladed propeller, with blades of different lengths.
What is the purpose of such an arrangement?
Sign up to join this communityThe Schempp-Hirth Duo Discus T powered glider has a five-bladed propeller, with blades of different lengths.
You are right. They are unequal length blades. Schempp refers to the propeller as being "noise optimized" and you can see that the blades are free to flap (forward) like helicopter blades (which flap up) so that the asymmetric thrust axis from having the propeller disc offset from the rotational axis doesn't place bending loads on the hub. And obviously, the blades will be mass balanced to place the center of gravity at the hub axis.
I'll go out on a limb here and say that some genius figured out a way to reduce the horrific noise level caused by such a small propeller by having the blade tips each run in a slightly different path of rotation. Brilliant.
And here it is in action where the eccentric blade disc can be clearly seen.
Just a guess, but it might be an attempt to reduce the chance of resonance at the blade frequency.
The tail will receive pressure pulses from each blade, but they won't be evenly spaced.
A motor like this is designed to be started and stopped during flight, and will this accelerate and decelerate through a range of speeds. Somewhere in the range between 0 and full power may be the resonant frequency of some part of the tail. When the motor hits that frequency, the tail could shake violently.
By spacing out the pressure pulses from the prop, there won't be any speed where they all resonate with the tail.
