If anybody could explain this in an intuitive way I'd really appreciate it. I haven't been able to find a clear answer on this. I understand that the increase in effective AoA/CL and the spanwise flow & resultant thickened boundary layer at the tip is responsible for the tip stall (if uncorrected for in the wing design), but I can't wrap my head around the reason why the effective AoA and CL increase in the first place. On a rectangular wing they decrease because of the upwash induced from the vorticies, so why doesn't it have the same effect on a swept wing? Most of the explanations I've found on here are geared for aerodynamicists and not the average joe pilot like me, and the explanations given in most pilot resources are overly simple if an explanation at all.
The book "Handling the Big Jets" by D.P Davies says "Too much sweep produces poor oscillatory stability and a tendency for the tip to stall, causing pitch up" and that's it..
ACE the Technical Pilot Interview by Gary V. Bistrow says "A simple swept and/or tapered wing will stall at the tip first [...] This is so because the outer wing section produces a higher wing loading due to the wing taper, which causes a greater angle of incidence to be experienced to a degree where the airflow stalls at the wingtips. The boundary layer layer spanwise airflow, also a result of sweep, further contributes to the airflow stalling at the wing tips."
This ATPL CBT video I watched says the airflow separation starts at the tips because the weak wingtip vortices allow separation earlier than the inboard part of the wing where the stronger vortices from the wider chord reduce the effective angle of attack... what?!
I have an interview coming up where this question could be asked, and I don't feel like I'd be able to deliver an answer with any sort of confidence at this point.
