I know that the TCAS II system has a lower antenna which can be either omnidirectional or directional. How does the functionality of the system change? If the antenna is omni then I think / assume that it cannot know the bearing of an intruding aircraft and therefore can not provide data to position it on a display. Is it only used for transmitting interrogation and/or receiving other data?
Thanks,
Ori
