I had a look at both
What is the equation for calculating static thrust?
and
Is there any equation to bind velocity, thrust and power?
However, it does not mention how much would the thrust be affected by the amount of blades. e.g if it was a 20 blade propeller with a given RPM, how much would it affect the amount of thrust
Could you please kindly help me with this? Thank you
