An airline filed the following flight plan:
[...] IRK.J96.SLN..LANCY.J134.PKE [...]
The cruise altitude was around 30k feet.
Waypoints in J96 are:
LAX PDZ YCDIL PKE* LANCY* DRK KEYKE GUP CIM GCK SLN* AGENT KIDER IRK* NORIS PIA JOT
J96 spans between 18k-45k feet.
So it means that someone put a direct in the middle of an airway. Why was the flight plan not filed with an all-airway routing like this:
[...] IRK.J96.LANCY.J134.PKE [...]
Is it common practice to omit some points in an airway?
    $\begingroup$ Guessing only, but maybe the direct is frequently approved and thus planning on it better reflects what will happen? It’s only a couple of miles, though... $\endgroup$ – Cpt Reynolds Jun 26 '19 at 10:14
  • $\begingroup$ It's 967 miles and as far as I saw it's not that common to fly direct $\endgroup$ – sacherus Jun 26 '19 at 11:20
  • $\begingroup$ I meant the shortcut is only a few miles shorter than following the airway... and hey, all I gave was a random possibility. Without speaking to the original planner, chances are we’re not going to find out the rationale behind the plan, anyway (or whether it was simply a typo or other glitch, for that matter). $\endgroup$ – Cpt Reynolds Jun 26 '19 at 11:31
    $\begingroup$ Objection your Honor, the question calls for speculation... $\endgroup$ – Michael Hall Jun 26 '19 at 15:40
  • $\begingroup$ Indeed we would have to speak with the original planner. I am new to industry, so I thought maybe it's a common practice to omit some points in the airway. If it's not then it's also valuable knowledge :). $\endgroup$ – sacherus Jun 27 '19 at 8:09
