I have been trying to model the pitching dynamics of a General Aircraft (Nelson : Flight Stability and Control) but during the modelling, I find that I need to use the Zδe which uses CZδe parameter, in the control matrix B but no where in Nelson a method has been provided to find it. Your help will be appreciated as I need to complete my work on an urgent basis. I am attaching a picture of the state space equations for your reference. Thank You![State Space Equations[![][1]]1]2
bumped to the homepage by Community yesterday
This question has answers that may be good or bad; the system has marked it active so that they can be reviewed.
The variation of Z-force with elevator deflection is simply the component in Z-direction of the lift force developed by the elevator. It is a function of:
  • Local Angle of Attack.
  • Elevator deflection angle.
  • Trim tab or stabiliser deflection.
  • Elevator surface area.
  • Local dynamic pressure at the elevator.
