30
I was on a flight from Philadelphia (KPHL) to Boston (KBOS), after some delay and some change of route due to weather, the captain announced that we will be cruising at 7000' due to delays in the area.
The history of the flight is here: https://flightaware.com/live/flight/AAL2606/history/20190618/2235Z/KPHL/KBOS
My question is two fold:
  • Why cruise so low with such an aircraft (A319)?
  • What is the impact on fuel consumption, knowing that we were also slower?
  • 9
    $\begingroup$ At that altitude, it is a violation of 14 CFR 19.117 to exceed 250 KIAS. I doubt this flight actually flew at 7,000. Flight Aware says it was filed for 17,000ft, and I suspect it actually flew at that height, but due to some technical error, the 10,000 part may have been left off? $\endgroup$
    – abelenky
    Jun 20, 2019 at 16:36
  • 10
    $\begingroup$ @abelenky FR24 also showed it at 7000' so I think they really flew that low (and reported at ~290kts ground speed so probably 250KIAS). Although it's very curious indeed. $\endgroup$
    – Sanchises
    Jun 20, 2019 at 16:58
  • 7
    $\begingroup$ I check with my phone gps it was 7000ft approx and the view to the ground was consistent with a flight that low. They also served drinks. $\endgroup$
    – Brice
    Jun 20, 2019 at 22:50
    $\begingroup$ Not an answer as this is pure speculation, but there may have been an issue with the cabin pressurisation system, but it was easier for them to fix that in BOS than in PHL for whatever reason. 7000 ft is approximately the altitude the cabin is usually pressurised to, so that would be consistent. $\endgroup$
    – jcaron
    Jun 21, 2019 at 8:00
    $\begingroup$ The captain said he was flying at 7000', flight aware says 7100', why is anyone doubting the accuracy of that? $\endgroup$
    – rtaft
    Jun 21, 2019 at 13:37
6 Answers 6
27
The only reason for your flight to operate at such low altitude is because it is cheaper for them to do so.
  1. As you said it is due to weather, other route/altitude may not be available. They can cancel the flight but that is likely to be costly. They may have to find accomodation for you and crew until they can put you to the next flight. Sub-optimal flight maybe better than no flight in this case.
  2. They may need that aircraft at that location the next day. If they choose to cancel your flight today, they will have to find a way to have this aircraft or another aircraft to fill in for the required flight the next day. They might as well fly a slightly more expensive flight at lower altitude rather than fly an empty plane to Boston.
  3. It is possible for them to wait for weather to improve but there is an issue of crew working hour. A pilot cannot work more than 8 hours in a day without provision for additional crew. They may approach that limit and the wait for weather to improve might means the airline has to provide another crew for the flight and might mess up crew schedule for the next few days.
So for the airline, in this case, flying lower and slower maybe a better option for them. Hence higher fuel comsumption is better than no flight.
I used the playback function of Flightradar24 for the 18th at 23:00 UTC, and the amount of traffic above 10,000' (filtering by altitude) seemed very normal compared to other days. I'm baffled as to why they flew so low, but I can address your fuel question in some detail.
The difference in fuel consumption is ~693 kg of fuel, and would cost an extra ~$415, which is certainly not disastrous, but can be a good profit on another short-haul flight (volume economics).
The decision to go ahead and fly low, as has been covered, is not just about fuel. There is a myriad of direct and indirect costs associated with cancelling a flight, and its knock-on effects.
How I arrived at the fuel figure:
The distance flown was ~360 NM (nautical miles). The more direct no-weather route takes 307 NM.
I'm limited by 10,000'/29,000' as the upper/lower limits of low/high cruise figures.
Cruising at a weight of 50 tonnes:
  • At 10,000' each engine burns 1028 kg/h while doing 280 knots true airspeed (indicated airspeed is 242).
  • At 29,000' each engine burns 1305 kg/h while doing 462 knots true airspeed.
Now to subtract the distance and fuel used in the climb/descent:
Climbing:
  • To 10,000' takes 11 NM and 336 kg of fuel (at a brake release weight of 52 tonnes).
  • To 29,000' takes 66 NM and 970 kg of fuel.
Descending:
  • From 10,000' takes 23 NM and burns 48 kg.
  • From 29,000' takes 64 NM and burns 114 kg.
Total:
For 10,000', that leaves 326 NM of cruise, which would take 2393 kg (two engines). Adding the climb/descent fuel would be a total of 2777 kg (trip fuel).
For 29,000', that leaves 177 NM of cruise (using the shorter distance), which would take 1000 kg (two engines). Adding the climb/descent fuel would be a total of 2084 kg (trip fuel).
Note: spending the shortest time in cruise (a flight that is mostly a climb followed by a few minutes in cruise) is the right strategy for short-haul flights, see: What should be the minimum time spent in cruise (for e.g. a B737)?
16
It was because they could get there faster on a "TEC route."
IFR flights are subject to congestion management at the ARTCC level, which means they have to wait their turn in line to be allowed into the airspace. That used to be done with holds (and still is in many other countries), but the US will slow down aircraft, reroute them or even delay takeoff to avoid holds, which saves fuel and therefore money. Most likely in this case, they were facing a long wait on the ground due to congestion in ZNY and/or ZBW.
However, if a flight stays low enough, it may be in contact with various TRACON facilities the entire way and never talk to an ARTCC, which means it can avoid the congestion and therefore leave immediately. This typically requires flying below 10k MSL for the entire trip, which is the normal boundary between the two. (It varies between 9k and 12k.) In fact, doing this in the NE US is so common that they've developed an entire suite of preferred Terminal En-route Control (TEC) routes to make it easier for both pilots and controllers.
Using TEC routes burns more fuel because the planes are flying lower and slower than normal, which is inefficient for turbine aircraft, but in some cases the airlines may decide that's better (i.e. less bad) than delaying or canceling a flight.
  • $\begingroup$ I'm not sure that the TEC part of your answer is correct, but the rest of the answer is. Departure delays for high altitude routes does occasionally leave the low altitude routes as the only reasonable option. I have never experienced this out of PHL, but I have often seen this out of TEB. TEB does not call it TEC routing, but low altitude routing. $\endgroup$
    – J W
    Jun 25, 2019 at 17:18
  • $\begingroup$ @JWalters: One of the route types is called TEC on FAA website. $\endgroup$
    – user14897
    Jun 28, 2019 at 14:21
  • $\begingroup$ @ymb1 Yes, a TEC (Tower Enroute Control) route is a type of route, but is not applicable here. A TEC route is by definition a published route (e.g., as found in the chart supplement). No TEC routes are published for PHL to BOS. The route flown shares many similarities with a TEC in that it was flown at low altitude and required no ATC service at the Center level. However, these non-published routes are generally called "low level" routes. Their use is relatively common, but they are not published. $\endgroup$
    – J W
    Jun 29, 2019 at 17:38
That’s a typical alternate route to KBOS by sending them direct to FJC VORTAC thence routed eastward. I suspect the real reasons for this are reduction of traffic congestion for NYC arrivals by ATC. On lighter days, they’re typically given the ROBUC3 arrival into KBOS immediately after departure from KPHL.
  • $\begingroup$ Does that route necessarily imply such a low altitude though? $\endgroup$
    – zymhan
    Jun 21, 2019 at 13:32
  • $\begingroup$ Not necessarily, but it can happen. And obviously the crew felt it was acceptable and flew it as opposed to requesting a higher altitude. $\endgroup$ Jun 21, 2019 at 14:24
  • $\begingroup$ @CarloFelicione Or perhaps they requested higher and were denied due to congestion that resulted from the storms. $\endgroup$
    – reirab
    Jun 21, 2019 at 15:52
  • $\begingroup$ Well they were filed for 17,000 ft. $\endgroup$ Jun 21, 2019 at 19:35
If they had an issue with the pressurization system, they'd fly that low. Why not cancel the flight? Well, that'd cost money. It'd be cheaper for them to fly low, eat the extra fuel costs and make buck on passenger fare. Who knows, maybe the part needed was nearby so they were going to have to route the plane there anyways.
    $\begingroup$ American's hub is in PHL. They wouldn't fly to an out-station to get parts. It also seems rather unlikely to me that they would operate a flight with a PACK and/or outflow valve inop. Does the MEL even allow that? Continuing flight under 10,000 if something goes inop while airborne is one thing, but knowingly beginning a flight with inop equipment is quite another. $\endgroup$
    – reirab
    Jun 21, 2019 at 15:35
-3
Possibly, the flight was too dangerous at a high altitude due to complications in weather, and therefore they decided to fly lower and slower. Flying at 7000' is very fuel-consuming, but they could do it since Philadelphia and Boston are fairly close together.
    $\begingroup$ You generally avoid adverse weather by flying ABOVE it, not below $\endgroup$ Jun 20, 2019 at 20:20
  • $\begingroup$ @J.Hougaard True, but you have to take off and land. Staying below weather may be a more predictable scenario than climbing and descending through it, when you are only flying a 360NM route. $\endgroup$
    – alephzero
    Jun 21, 2019 at 11:43
    $\begingroup$ @alephzero The problem with weather is that is usually goes from ground level up to some upper level. There is very rarely a clear area below adverse weather (gravity tends to do its thing) $\endgroup$ Jun 21, 2019 at 13:23
