Illustration taken from this youtube video
Earlier in the video, it can be seen moving:
Is it to provide mechanical power for the boom operation ?
It’s a ram air turbine which drives a fuel pump to provide pressure to transfer gas through the hose and drogue to the receiving aircraft.
    $\begingroup$ Any source ? Why not use electric power ? $\endgroup$
    – Antzi
    Jun 20 '19 at 6:22
    $\begingroup$ @Antzi from the linked duplicated question, "Pods operate with aircraft power or are self-powered by a Ram Air Turbine.". Also, the same solution is used on some EW pods $\endgroup$
    – DeepSpace
    Jun 20 '19 at 6:47
    $\begingroup$ I believe it actually powers the hydraulic pump for the reel that runs the hose in and out. $\endgroup$ Jun 20 '19 at 15:22
