I'm curious what propeller is used for the Aeriana Sirocco. Online I see lots of pictures of propellers with three blades, but none with only two and I cannot find many clear pictures of the proppeler. Are there any Aeriana Sirocco aircraft flying around with (wooden) propellers with only two blades?
  • $\begingroup$ It's powered by a Rotax 447, and there are a ton of props you can use for that, mostly composites (carbon) and some wood, with or without reinforcement. $\endgroup$ Jun 14, 2019 at 10:36
  • $\begingroup$ @JuanJimenez thank you a lot! $\endgroup$
    – Nathan
    Jun 14, 2019 at 12:23
  • $\begingroup$ If this is the same aircraft as the Aviasud Sirocco then you can see lots of pictures in Google image search and many have a two-bladed prop. $\endgroup$ Jun 14, 2019 at 20:26
