Do I need to add elevator downforce to total lift when sizing wing area?
Say a small airplane weighs 1,000 lbs, and both the wing and elevator have a max Cl of 1.5, and my elevator is 20% of my wing area, so max elevator downforce is roughly 20% of 1,000 lbs or 200 lbs in a classic configuration.
Doesn't the main wing then have to carry 1,000lbs + 200 lbs negative elevator lift, for a total lift of 1,200 lbs?
If the plane is in a tandem configuration, the main wing would only have to carry 800 lbs, as the elevator has 200 lbs of positive lift,for a total lift of 1,000 lbs.
1,200/800 lbs is 150%!!, so if I use the tandem configuration, my main wing can be 50% smaller!!! Is this correct?
