In order to classify parts for export I need to determine where our parts go on the plane. (Engine or structural/body) Specifically looking at the canister, heat shield assy and lock support for the Boeing 767/777.
  • $\begingroup$ It might be easier to answer your question if you provided a bit of context. $\endgroup$ – expeditedescent Jun 13 '19 at 14:24
  • $\begingroup$ Already how do you identify these parts. Just numbers or otherwise? $\endgroup$ – user40476 Jun 13 '19 at 14:28
  • $\begingroup$ I assume you are not the manufacturer? If so, you need access to some sort of database that will give you that info, In some cases a Google search will answer the question, but in obscure instances you may not find what you want. $\endgroup$ – Juan Jimenez Jun 13 '19 at 14:35
    $\begingroup$ Export related questions are best addressed to your compliance department or person. Just saying. $\endgroup$ – AEhere supports Monica Jun 13 '19 at 15:14
  • $\begingroup$ Do you really trust somebody on the internet to classify your part for export for you? $\endgroup$ – vasin1987 Jun 13 '19 at 15:25
What you need is a parts catalog/diagram.
Here is one for the 767 that shows parts and where they go. Interestingly all the pictures seem to be of the BBJ (business jet) version of the 767, the other parts should remain the same.
