It seems nicely symmetrical that opposite ailerons would be locked togther, so that when the left wing's ailerons move up, those on the right wing would move down, by the same amount and at the same speed.
Is this in fact generally the case on aeroplanes? Or can they be moved independently, or at different rates or to different positions (and what advantage would that offer)?
Finally, are there any aeroplanes on which they can be moved in the same direction?
    $\begingroup$ That's pretty much what they do so I'm not really sure what you are asking. And if they moved in the same direction they would not functionally be considered ailerons, they would be either flaps or spoilers. $\endgroup$ Commented Jun 8, 2019 at 0:59
    $\begingroup$ @MichaelHall: There is also a combination, called flaperons. They move together with the flaps and - by means of a mechanical mixer - work as ailerons on top of that. $\endgroup$ Commented Jun 8, 2019 at 6:48
  • $\begingroup$ @MichaelHall It seems that that is what they would do, but I understood that in fact it's not what they always do, hence the question. $\endgroup$ Commented Jun 8, 2019 at 8:36
On most general aviation airplanes, and other cable-controlled aircraft, they move together and for that matter are cross linked to the same physical cable. You can see this nicely on the control diagram for the B-24
enter image description here (source)
Some ailerons are designed to counteract adverse yaw and may move such that they are asymmetrical to the flow over the wing.
1) Differential Ailerons: One aileron is raised a greater distance than the other aileron is lowered. The extra upward aileron movement produces more drag change than an increase in AOA on the downward aileron. This produces an increase in drag on the descending wing, which reduces adverse yaw.
2) Frise Ailerons: The aileron being raised pivots on an offset hinge. The leading edge of the aileron is now pushed into the airflow, creating drag and reducing adverse yaw. In this case, frise ailerons are using form drag to counter induced drag.
But not all aircraft contain such systems. Fly-by-wire systems are theoretically capable of deflecting any control surface as they see fit and may not move symmetrically but generally speaking their direction of movement is opposite. Some fly-by-wire aircraft even have split ailerons which may see parts of a give aileron deflect differently. This answer covers that quite nicely.
If you really want to go back, the 1912 Farman HF.20 had single action ailerons that only deflected downward and were pushed back into position by the airflow. I would say (if these count as ailerons) that they do in fact not move in tandem. There were some other early designs covered here that worked a bit differently than modern ailerons.
As for your second point, aircraft that have elevons, which serve as both the elevator and the aileron (mostly delta wing stuff like the Concorde and other high speed airframes), can move the surfaces in the same direction. Generally other surfaces are employed for the use case of needing to move both ailerons in the same direction (speed brakes).
  • $\begingroup$ Pictures of the HF.20 on the ground show both ailerons in line with the wing. You need to go back to earlier types like the Voisin-Delagrange to find one where both ailerons were hanging down, clearly indicating that they were free-floating in operation. $\endgroup$ Commented Jun 8, 2019 at 6:50
    $\begingroup$ IIRC the A320 raises both ailerons to support the ground spoilers after landing. $\endgroup$
    – Florian
    Commented Jun 8, 2019 at 7:19
Or can they be moved ... at different rates ... ?
I saw a power glider (maybe an SF-28 or an RF-5) where the ailerons moved with a different rate.
The reason was an effect whose German name translates to "negative turn effect", but I don't know the correct English word for it:
If you operate the ailerons to the right, the ailerons work in a way that the left wing produces more lift and therefore more air resistance than the right one.
Therefore operating the ailerons to the right will also have a similar effect as operating the rudder to the left. (For this reason the rudder has to be operated to the right together with the ailerons to compensate that effect.)
The power glider I have seen was built in a way that the left aileron only did a much smaller motion then the right one when putting the stick to the right. By doing so, the right aileron worked like an air brake so the air resistance of both wings was nearly equal and there was no "negative turn effect".
There are airplanes that use "flapperons":
This means that the same part is used as flap and as aileron.
Being used as flaps, the flapperons move in the same direction; being used as ailerons, they move in different directions.
The basic principle of ailerons is that the aileron on the down-going wing will deflect up, and the aileron on the up-going wing will deflect down. But the movement usually isn't equal on both sides.
Moving the aileron down increases the wings camber and therefore lift, which also comes with drag. This drag produces a yawing effect opposite to the desired turning direction. This is known as adverse aileron yaw, and needs to be overcome by coordinated use of the rudder when banking.
There are a few different ways of reducing this adverse yaw, the most common of which is known as differential ailerons. This is where the aileron that deflects up has a greater range of movement than the one that deflects down, reducing the drag on that side for the same banking force.
On a side note, airliners don't use ailerons at all at high speeds, because doing so will twist the wing. Spoilers are used instead for roll control in cruise as they are closer to the wing root, thus providing less twist. They operate only by deflecting up on the one side.
    $\begingroup$ The airspeeds required to cause significant wing twist from aileron deflection in airliners are generally well above said airliners' never-exceed speeds. $\endgroup$
    – Vikki
    Commented Jun 8, 2019 at 3:32
    $\begingroup$ @Sean: Depends on what is significant to you. Boeings, Illyushins and most other airliners use high speed ailerons in the gap between inner and outer flaps, so the outboard ailerons need only be used in slow flight. Only Airbus doesn't. At cruise aileron effectivity is markedly reduced because of wing twist. Only a reversal speed below v$_{NE}$ would make certification impossible. $\endgroup$ Commented Jun 8, 2019 at 6:57
