I am taking a check-ride at an unfamiliar airport. How should I look for a practice area for maneuvers?
    $\begingroup$ Ask a local. You really should familiarize yourself with the area before your check ride. It's stressful enough without adding unfamiliarity to the mix. $\endgroup$
    – Ron Beyer
    May 30, 2019 at 16:25
  • $\begingroup$ If you're doing a checkride (one assumes with an instructor) won't they show you the practice area(s) they typically use? $\endgroup$
    – Jamiec
    Jun 3, 2019 at 8:13
