In World War 2, how did aircraft navigate to the carrier after their mission? I was thinking of something like a beacon installed in the carrier but wouldn't it reveal the location of the carrier itself?
You are correct. US carriers did indeed have a homing beacon that enabled aircraft to find them.
The carrier transmitting units were called YE or YG, and the receiving units in the planes were designated ZB, and called "Zeebies". The transmitters consisted of rotating "superfrequency" beacons that broadcast different morse letters in different directions that could be decoded by the ZB units, but sounded like static to ordinary listeners. They were installed on all US carriers in WW2.
Here is an excellent summary of the system and its history. More information can be found here and here, and History SE already has a question about it.
The British also had a similar system, installed on a carrier in 1936 and used through the war.
Sources also indicate that the Japanese employed a radio homing system (Hirohito's War by Francis Pike), but I have been unable to locate any details.
$\begingroup$ Also on Wikipedia: AN/ARC-5 § Homing adaptors and VHF $\endgroup$– user14897May 28, 2019 at 21:31
1$\begingroup$ It amazes me every time I learn about WW2 techs... thank you for the explanation. $\endgroup$– JaebumMay 29, 2019 at 9:47
$\begingroup$ I understand that radio-based homing was available to all carriers during WW2, from the beginning? $\endgroup$ Apr 1, 2022 at 18:29
American carriers were fitted with a line-of-sight radio homing system, but Japanese aviators were probably limited to old-fashioned dead reckoning, since Japan was less advanced in electronics than the U.S.
6$\begingroup$ Japanese carriers had sonar, radar, fire control directors – how is a radio beacon too advanced then? $\endgroup$– user14897May 26, 2019 at 12:35
3$\begingroup$ This answer could be improved by including references $\endgroup$ May 26, 2019 at 13:20
