POH manuals always tells to use the voice of the engine as a reference. (Which complicates things a little bit since carbs and fuel injected planes have different "reaction times" for each cylinder)
But how do you lean the mixture without using your ears? How do you lean mixture with only the instruments as a guide?
Lets assume we have a brand new C172 Skyhawk
