Researching the etymology of 'rotate' (that OED lacks!), I chanced on Anas Maaz's Quora answer:
What many does not know is 'rotate' is just not a fancy word, but it involves a real physical rotation. When Rotation speed (Vr) is reached, the pilot pulls the control column which deflects the horizontal stabilizer, causing a rotation along the lateral axis of the airplane lifting up the nose wheel.
  1. Am I correct that Maaz's referring to the 'lateral axis' in the diagram beneath?
  1. Even if yes, what exactly ROTATES? How does the lateral axis ROTATE?
Imagine the wing on the y-axis and time on the x-axis, like the graph beneath. I don't think it's correct mathematically to state that an axis rotates, when it's the function that moves up as time passes?
  • $\begingroup$ An interesting mathematical subtlety is that in general, rotations occur in a plane as opposed to about axis. It just so happens that in 3D, a plane has an orthogonal axis. But there is not axis to a plane in 2D space, although you can rotate things to your heart's content. In 4D and higher, you get all kinds of weird. $\endgroup$
    – MikeY
    May 20, 2019 at 16:47
  • $\begingroup$ Note that the quote in your question does not say the axis rotates, but that the plane rotates along the axis. $\endgroup$
    – TomMcW
    May 20, 2019 at 17:19
  1. Yes that is the lateral axis of the aircraft.
  2. The aeroplane rotates about the lateral axis, causing the nose to go up/down. The aeroplane then descends or climbs, causing the aeroplane axes to shift relative to earth axes. But the aeroplane axes are all defined relative to the aeroplane.
    $\begingroup$ One tiny nitpick. Before liftoff the axis of rotation is actually the landing gear axles rather than the cog as it is in flight. $\endgroup$
    – TomMcW
    May 20, 2019 at 17:22
1: Yes, rotation around the lateral axis will make the aircraft pitch. You understood that correct. On the other hand lateral rotation means something else, namely roll.
2: Its not the axis that rotates, its the aircraft that rotates. The axis is in a body fixed reference coordinate system, hence the whole coordinate system (and aircraft) rotates in relation to earth.
