4$\begingroup$ Where is the aircraft in the picture located? $\endgroup$ – nexus_2006 May 13 '19 at 21:43
1$\begingroup$ @nexus_2006 probably Kelly AFB. It was on display there for years (1957-2004). Sadly, I didn't go see it in time. $\endgroup$ – Organic Marble May 14 '19 at 2:09
Based on the unique 6x pusher-prop configuration, this looks like a derivative of the Convair B-36 Peacemaker. Looking up the Wikipedia article for the B-36 and scrolling down to the variants section, this seems like an XC-99 (or, more aptly, the XC-99):
Public domain image via United States Air Force - USAF photo via, Joaobsen, Wagner, Greer (1980), B-36 Peacemaker in action - Aircraft No. 42, Squadron/Signal Publications; 1st edition, ISBN-10: 0897471016
This was to be a passenger variant of the airframe, with a passenger capacity of up to 400 people. Beyond the prototype, it didn't enter service.
2$\begingroup$ Interestingly, the B-36 was involved in the first Broken Arrow incident where three of its six piston engines caught fire off the coast of British Columbia. $\endgroup$ – coconaut May 13 '19 at 22:31
2$\begingroup$ @coconaut if you're interested in other B-36 trivia, there was also a variant, the NB-36H, powered by a nuclear generator which was supposed to combine the endurance of a nuclear submarine with the airworthiness of something that's distinctly not a nuclear submarine. $\endgroup$ – 0xdd May 14 '19 at 13:57
XC-99, o e was built and was on display for years at Kelly AFB, Texas and later moved to the Air Force Museum.
$\begingroup$ This does not provide an answer to the question. Once you have sufficient reputation you will be able to comment on any post; instead, provide answers that don't require clarification from the asker. - From Review $\endgroup$ – Ralph J May 14 '19 at 22:56
4$\begingroup$ @RalphJ The information in this answer is correct and does provide an answer to the question. The only problem is it doesn't provide info that wasn't in the other answer already. $\endgroup$ – Hobbes May 15 '19 at 11:21
