This flight of 2 flew by my house in Eugene, Oregon recently. I assume they're military pilot trainers but I am having trouble coming up with an ID.
1$\begingroup$ Welcome to aviation.SE! $\endgroup$ – Pondlife May 10 '19 at 23:59
$\begingroup$ Thanks for the comments and links Redd Herring and YMB. I had been leaning towards the A29 (EMB 314) and your posted photo of the EMB 312 looks good to me Redd. I looked at Texans too and even though there were several canopy changes none matched my planes. The info on Military Tech pretty much cinches it. They are based at EUG and I live on a 3 mile final to Ry34. I'm a former controller at EUG and don't recall working these aircraft there so am guessing these are fairly recent acquisitions. $\endgroup$ – elepaio May 11 '19 at 3:32
1$\begingroup$ Welcome to Aviation.SE! I put this on the answer you posted but I'll put it here as well in case it gets deleted. If you think an answer is correct you should press the green tick to mark it as accepted rather than post another answer yourself. If you haven't already done so, I'd recommend taking our tour and read the help center so you can see how this site works. $\endgroup$ – Notts90 supports Monica May 11 '19 at 9:14
Add a comment
1$\begingroup$ @ymb1 Perhaps, but it might just be to do with the angle of the photo. The other candidate is the AT-6 Texan II, but that seems to match rather less well. $\endgroup$ – CatchAsCatchCan May 10 '19 at 23:55
$\begingroup$ This is as close to the angle as I could find. A different dorsal fin and the presence of ventral fins (similar sun angle). $\endgroup$ – ymb1 May 11 '19 at 0:14
They are most likely Embraer EMB 312 Tucanos. Military Tech, Inc. has at least 10 registered in Eugene. Here is one in a similar paint scheme:
1$\begingroup$ Here are photos for one of those registered in OR. $\endgroup$ – ymb1 May 11 '19 at 0:38
$\begingroup$ Wow what are they doing with 10 of those planes in Eugene? Do the hippies know? (Real question, the first I mean) $\endgroup$ – quiet flyer May 11 '19 at 8:03
1$\begingroup$ Military Tech is a local group that buys and refurbishes surplus military aircraft. When I worked at EUG (5 years ago) they were doing mainly helicopters. It looks like they're expanding to fixed wings. $\endgroup$ – elepaio May 12 '19 at 0:24
