How can pilots obtain official runway length information for airports that do not appear in the chart supplement such as private airports?
2$\begingroup$ A lot of private airports, as long as they appear on a chart will also appear in the chart supplement. Otherwise you'd have to call the airport operator (which you would need permission from anyway to land there). Do you have an example of an airport that is on a chart, but not in the supplement? $\endgroup$ – Ron Beyer May 10 '19 at 2:47
$\begingroup$ Horseshoe Acres, and Brady east of lake Okeechobee in FL $\endgroup$ – Ryan Mortensen May 10 '19 at 2:55
$\begingroup$ You can't obtain official runway length information, if you could they'd be in the chart supplement. $\endgroup$ – GdD May 10 '19 at 7:29
If an airport does not appear in the Chart Supplement, the only official information about it seems to be in the relevant Sectional Chart.
In the case of Horseshoe Acres (FA24), the sectional shows that the longest (and only) hard-surface runway is "18", which means 1770 to 1869 feet.
In the case of Brady Ranch (80FD), the sectional shows that the longest (and only) hard-surface runway is "46", which means 4570 to 4669 feet.
Note that you can only guess the runway numbers, the lengths of shorter runways, and the presence of unpaved runways. As @RonBeyer comments, since you have to get permission to land on these fields anyway, it's probably best to ask for such details at the same time. If you get data from the airport operators themselves, that would seem to qualify as official.
However, Airnav and others have lots of consistent data about many airports not in the Chart Supplement, particularly private ones, so it's possible there is some other common source. Since I don't know what that might be, I can't guess how official it is.
Just use the ruler feature for measuring distances down to feet in Google Earth. Not "official" but pretty accurate.
4$\begingroup$ For emergency,yes. But not for normal operation. You have no idea when is the last time google update their maps. The airport may not even be there. $\endgroup$ – vasin1987 May 10 '19 at 5:36
