I saw this plane flying out from Prestwick airport yesterday but what is it?
Photograph of unidentified 4 engine airplane
Based on the fact that this looks like a 4-engined jet, with a T-tail, and winglets. I think it is a C-17.
From wikipedia, C-17 deploying paratroops
(wikimedia.org)
| improve this answer | |
  • $\begingroup$ Number of Küchemann bodies also matches, and the ramp might be identifiable as well. Looks like the correct answer. $\endgroup$ – AEhere supports Monica May 7 '19 at 13:32
  • $\begingroup$ It's also got the landing gear in fairings under the fuselage, which is a common setup for military transports (to keep the inside load space wide for the full length). A little sub-fin also helps agreement with this type. $\endgroup$ – Zeiss Ikon May 7 '19 at 13:33
  • $\begingroup$ C-17's fly in and out of Prestwick regularly. Prestwick has the longest commercial runway in Scotland (Macrihanish is longer) so it's a useful facility for exceedingly large cargo aircraft. $\endgroup$ – Rory Alsop May 7 '19 at 14:26
  • $\begingroup$ And the C-17 is the only four-engined jet cargo aircraft flown by the RAF. (Of course, we don't know from the picture that this is an RAF plane.) $\endgroup$ – David Richerby May 8 '19 at 11:23
It's a C17.
RCH560 C17 08-8193 arrived off the ocean about 0225L
As taken from this forum
    $\begingroup$ Good find! RCH has the callsign Reach and is commonly used for USAF C-17 flights. $\endgroup$ – fooot May 7 '19 at 14:49
